Looks like a nice, smooth graph. Regarding the old engine, yes detonation to the max! And 330bhp on standard injectors? They are pretty much maxxed out around 300bhp so it was probably running way too lean with DC of 100%
Thanks! TuneForce from Poland do the ecu map. Not much LB/FT right now cause I use Athena gasket 1,6mm x 84,5mm. Later we will do new ecu map with Bosch 714CC injectors and 3 bar press-sensors with higher boost 1,6 bar, so it should be nice
I have 265LPH fuel pump so standard injectors works fine, AFR is correct. Friend of mine running 322HP with same config as my car and everything is ok.
I got them on the Polish online auction service. It wasn't easy. I was looking for them for over three years... @Big Steve - Raider
Custom painting door bullets - made by my friend Step-by-step photo-taking.
