Peter T
One Top Fuel dragster's 500-cubic-inch Hemi engine makes more horsepower than the first four rows at the Daytona 500.
A stock Dodge Hemi V-8 engine cannot produce enough power to drive the dragster's supercharger.
With 3000 CFM of air being rammed in by the supercharger on overdrive, the fuel mixture is compressed into a near-solid form before ig-nition. Cylinders run on the verge of hydraulic lock at full throttle.
At the stoichiometric 1.7:1 air-fuel mixture for nitromethane, the flame front temperature measures about 7000 degrees Fahrenheit.
Nitromethane burns yellow. The spectacular white flame seen above the stacks at night is raw burning hydrogen, separated from atmospheric water vapor by the searing heat of the exhaust gases.
Dual magnetos supply 44 amps to each spark plug. This is the output of an arc welder in each cylinder.
Spark plug electrodes can be totally consumed during a single pass. After half-distance, the engine is dieseling from compression plus the glow of exhaust valves at 1400 degrees Fahrenheit. The engine is shut down by cutting the fuel flow.
If a spark plug fails early in the run, un-burned nitro can build up in the affected cylinder and explode with sufficient force to blow the cylinder head off in pieces or split the cylinder block in half.
In order to exceed 300 mph in 4.5 seconds, dragsters must accelerate at an average of more than 4 g's. In order to reach 200 mph before half-distance, the launch acceleration approaches 8 g's. A Top Fuel dragster reaches more than 300 mph before you have completed reading this sentence.
With a redline that can be as high as 9500 rpm, Top Fuel engines turn approximately 540 revolutions from light to light. Including the burnout, the engine needs to survive only 900 revolutions under load.
Assuming that all of the equipment is paid off, the crew works gratis, and nothing breaks, each run costs an estimated $1000 per second.
The current Top Fuel dragster elapsed time record is 4.441 seconds for the quarter-mile (October 5, 2003, Tony Schumacher). The top-speed record is 333.25 mph as measured over the last 66 feet of the quarter-mile (November 9, 2003, Doug Kalitta).
Putting all of this into perspective: You are driving the average $140,000 Lingenfelter twin-turbo Corvette Z06. More than a mile up the road, a Top Fuel dragster is staged and ready to launch down a measured quarter-mile as you pass. You have the advantage of a flying start. You run the Vette up through the gears and blast across the starting line and past the dragster at an honest 200 mph. The "tree" goes green for both of you at that moment. The dragster launches and starts after you. You keep your foot down, but you hear a brutal whine that sears your eardrums, and within three seconds, the dragster catches you and beats you to the finish line, a quarter-mile from where you just passed him. From a standing start, the dragster spotted you 200 mph and not only caught you but nearly blasted you off the road when he passed you within a mere 1320 feet.
The nitromethane-powered engines of NHRA Top Fuel dragsters and Funny Cars produce approximately 8,000 horsepower, about 43 times that of the average street car. In fact one cylinder of the eight cylinders of a Top Fuel dragster or a Funny Car produces 750 horsepower, equalling the entire horsepower output of a NASCAR engine
An NHRA Top Fuel dragster accelerates from 0 to 100 mph in less than .8 of a second, almost 11 seconds quicker than it takes a production Porsche 911 Turbo to reach the same speed
Under full throttle, a dragster engine consumes 1.5 gallons of nitromethane per second; a fully loaded 747 consumes jet fuel at the same rate with 25% less energy being produced. The nitromethane used to power the engines of NHRA Top Fuel dragsters and Funny Cars costs about $30 per gallon and they use between 10 and 12 gallons of fuel for a complete pass, including the burnout, backup to the starting line, and quarter-mile run
A fuel pump for an NHRA Top Fuel dragster and Funny Car delivers 65 gallons of fuel per minute, equivalent to eight bathroom showers running at the same time. The fuel-line pressure for NHRA Top Fuel dragsters and Funny Cars is between 400 and 500 pounds, about 20 times greater than the pressure on passenger-car fuel pumps
It is desirable for an NHRA Top Fuel dragster to race with its front wheels inches off the ground for about the first 200 feet of the run. This ensures proper weight transfer to the rear wheels, a crucial part of a good launch and quick run
An NHRA Funny Car is slowed by a reverse force more than seven times that of gravity when both parachutes deploy simultaneously
