Hi guys, you're all well.
Firstly, my carb is off a renault 5 gt but it's on my pinto. I've had it running before and it's been something tried and tested by others.
I cannot get the car to start. I've taken the carb apart, replaced all gaskets, needle valve etc from overhaul kit. Accelerator squirt is working as I can see it shooting fuel into throat when manually turn the throttle. Fuel is in the float chamber. If the missus sits in the car and I continually spray easy start in the carb it'll run. This leads my to think it's fuel delivery at fault? Perhaps issue jet needs replacing or mixture screw needs replacing. To be fair these are the only parts not been replaced.
I appreciate this isn't a standard set up but it has run before and any suggestions around the carb would be greatly appreciated.
Just for info, got fuel injection pump on there and malpassi carb regulator in there.
Cheers, Dave
Cheers, Dave
