Sills
blakey
Is it me or are the sills, and buy that I mean the jacking points are not designed for lifting a Clio rear end + 3.0 v6. Dont seem strong enough. I have had to cut wooden supports for mine when jacking it up.
Anyone else think this?
Yes, they are shite! If you are jacking the rear end, I use two trolley jacks simultaneously on the rear subframe corners (aft end corners) - with rubber pads. These are good strong locations, and it does not risk bending the subframe like if you were to jack in the centre of the rear beam.
