5 GT Turbo Servo and master cylinder upgrade
As per title, wondering what the options are for upgrades. will be running 310mm Hi specs
Cheers
I went up to 330mm discs and 4-pots and found I didnt need to upgrade on the 21. I believe @la21t went to Monster 6-pots and thats OK too.
Try it out before you blow cash on new cylinders. Yes pedal travel increased a tiny bit but nothing that caused concern.
Master cylinder will need an upgrade or the pedal travel will be shocking iirc i think a golf master cylinder fits. Might be worth looking at the clio 172 non abs servo and master cylinder see if it goes on
T
I read somewhere that the 172 Cup fits but two of the ports are M10x1.0, the other two are M12x1.0.
That's right I got clio 172 servo and master cylinder fitted to my 5 just use a male to female adaptor for m12 to m10 and one other issue the fitment to brake pedal is different on the rod on the servo I cut off the 172 rod end and welded on a Gtt end other that the servo fits
