Clio S/C ph1 172 boost bus
NO.
Please DO NOT dangle shit like that in my face! Jesus, I got five kids to feed!
(I don't have five kids really, it's a Total Recall reference for those of you too young to remember classic Arnie!)
Lol
So that kit including my (cheaper than k tec )brackets £ 1850
New aux belt £12-15
Megan 225 injectors and spark plugs - £ 162 /£42
Fuel system -£200 ish including ph1 type return and walbro 225
Intercooler and pipes £-200ish for an eBay set up - same as k tec
Efi boost module and mapping - £550
Clio 172 / 182 RS TURBO ECU kit - EFI-Parts.co.uk: Connectors, Sensors, Trigger wheels, Wideband, Adaptronic, Zeitronix, AEM
You will also need to fit a megane bottom crank pulley so a cam belt, if you are due a belt ideal time really
So good enough to run up to 280-bhp but realistically you want to stick to 250-260 on a standard bottom end
So what almost £3000 (without a cam belt) And it really is a fit on your driveway in a weekend kit
Small updates, I'm now at the stage of making a support bracket that fits around the sm inlet
i660.photobucket.com_albums_uu322_marinemackay2003_rebuild_E06a942cae81984e9decd7db858005047df.webp
As you can see there is no space to run the stabilizer bar that bolts to the block so a little bit of work is needed to get around this
I think it's going to be a lot more stable with it as Renault put it there for a reason and I would feel a lot more reassured knowing that the aux belt is not going to fly off etc
The bottom mount ? The subframe to gearbox one if so yes its rubber
sorry i mean the bottom mount for the alternator. On early renaults is a rubber bush and bolt. I think the clio one is essentially solid mounted when bolted up tight? yeah get you, dont want a belt coming off and killing the engine.
so had a bit more time on the car this weekend
i660.photobucket.com_albums_uu322_marinemackay2003_rebuild_0BA0bf25d26045c46b93d73250589710ed9.webp
engine mounts are in, so much space
so then needed to move the battery to the boot/under seat, i am going for boot as will be fitting a large battery, done it correctly with a through bulk head connector, looks fairly smart
i660.photobucket.com_albums_uu322_marinemackay2003_rebuild_C33ef9ae0eeabf195a146b9739b3ac667e4.webp
finally got round to sorting a bracket to replace the support bar, its not great looking but its very robust and should stop any movement side to side
i660.photobucket.com_albums_uu322_marinemackay2003_rebuild_CADb5d070cb351060ac0a4fbd7807d97a63.webp
cars looking a little bit neglected at the moment but bodywork and wax are wayyyy down the list
i660.photobucket.com_albums_uu322_marinemackay2003_rebuild_1B043a8e2940326c97fadfee8d8fa50ca1e.webp
and the duty workshop sticker seems to found a home......knobbers
i660.photobucket.com_albums_uu322_marinemackay2003_rebuild_2CF97a25d5093ad3e447505e834c87cd8ff.webp
So got the new exhaust fitted today - rather rare now, yozza race system
i660.photobucket.com_albums_uu322_marinemackay2003_rebuild_3BFc3e5357e2b41ab44f3e58fba904b4019.webp
Then switched to getting the charger sorted
i660.photobucket.com_albums_uu322_marinemackay2003_rebuild_EF4fad76827492b1506fe59c0b2a3b10b7b.webp
Mounted up all fine, then turned my attention to addressing the imo 3 - 4 major failing points of the s/c on clios
1. Overspeeding
2. Overheating
3.Alignment / elevation of oil circuit
4. Fragile brackets
1 and 4 are sorted with the bigger pulley and new stainless steel brackets
So number 2 and 3 I have tried to follow Rotrex advice
"To prevent oil leaks it is of utmost importance that the oil cooler, oil filter and the oil canister with its cap are placed below or level with the supercharger shaft"
I have positioned it all like this
i660.photobucket.com_albums_uu322_marinemackay2003_rebuild_8CA2d9725076382ffc8f3ac403f28fa3bdb.webp
So not to bad for alignment imo bar the oil cooler but that can't be helped, placing in this position will massively aid cooling though
i660.photobucket.com_albums_uu322_marinemackay2003_rebuild_8D97c34b661464aeea6db84ca19ea6ff38a.webp
s/c oil cooler on left in large volumes of airflow
And the view of the oil reservoir through my brake duct
i660.photobucket.com_albums_uu322_marinemackay2003_rebuild_79D3e3ed18fd22b4540af7cae62bcedc241.webp
So also in plenty of airflow, I will also be fitting a temp sensor and gauge inline to monitor temps , in this location I will also be able to easily check fluids
i660.photobucket.com_albums_uu322_marinemackay2003_rebuild_820100b6df553dc6ce42ba0be7f64dacd71.webp
So just to plumb it all in tomorrow
