Just read the following post on Pistonheads in response to a query about changing oil ahead of the recommended service interval. The following post was by someone purporting to be an 'Automotive Engineer', and since I am not sure whether it was posted in jest, as I had never heard such a thing before, I thought I would check with those of you who fettle engines and/or are mechanical engineers.
"Actually the oil filter is designed to let through shavings that help run in/hone the engine. If you drain the oil early, those are literally down the drain and usually won't come back... That said running in usually ain't very critical apart from bedding the piston rings perhaps."
The said car does not appear to have a running-in service in its maintenance schedule. As such, what do you think?
