Megane RS250 engine into R26 - using mk3 fuel pump
Ewan
I am swapping the engine in my R26 with a RS250 unit retaining the R26 ECU and loom. Should clarify at this point that 'I' means 'I am paying Rentec in Edinburgh' ;)
Ok, so we are keeping the R26 ECU and loom and swapping in the RS250 engine with turbo and the mk3 inlet manifold, fuel rail and injectors.
I know that we should be able to run the RS250 engine with the existing mk2 fuel pump, although it won't offer the rising rate fuel pressure. The question is can we fit the mk3 fuel pump to my car and take advantage of the rising rate rail with the mk2 ECU and loom without a massive headache?
Finally sourced a 225 fuel pump. I will take some pictures of the pump and fpr for reference and check to see how the 250 fpr fits.
Any news on the Lexus sender and fpr?
Found out a 197 has a completely different fpr compared to the 225 and 250. My luck is i had already bought a 1.2 sender which does seem to work!
The dw65c is a direct fit aswell
I have no experience with them tbh.
Yes the 1.2 has a 3,5bar regulator, there's no marking on the 197 so god knows what pressure it's running but i'm assuming 3,5bar aswell
Just looked into the itp116 but afaik it's longer then the original pump.....
I think you need the dw65c
Picked up a dw65c during the week and I can confirm it is a direct swap for the standard Bosch pump. If you are buying one, then the universal pump without clips is the one to get. Need to retain the original pumps sock as the generic one they provide doesn't fit.
Hopefully get this fitted middle of next month. As this pump draws a fair bit of current, something like 10A+ at 3.5bar, it will need a direct line from the battery.
Doing a bit of digging on the web and came across this external fuel pump and surge tank suitable for returnless systems. Much want, however also much expense :)
FST-R, Fuel Surge Tank with Integrated FPR
You could replicate that with a normal swirl pot, an external pump, and some AN6 fittings. Its just a repositioning of the regulator in the system loop thats all. Normally you go around a full loop
Swirl>Pump>Rail>Reg>Swirl
but with a returnless you go
Swirl>T-Piece (T1 and T2 being the outlets)
T1>Reg>Swirl
T2>Rail
The downside being if the reg is at the back you cant really fit a vacuum reference to the reg for rising rate, which you need on a turbo car to equalise the differential between manifold pressure and fuel pressure unless you run a high enough static fuel pressure for that not to matter, so a minimum of 3bar plus your max boost pressure.
For my application I wouldn't need the vacuum reference, a static 3.5bar would do the job. If you use the RS250 fuel rail, you have an additional reg on the rail that you can attach a vacuum reference.
The biggest advantage imo with this setup is that it sinks the pump inside the surge tank which should help to cool it, and keep the noise down. Also you don't have the problem of warm fuel returning to the surge tank in the return less system.
Didn't think it was too bad a price for the unit, it's just a lot of money to throw at a car!
Yeah, the dw65c was a straight swap into the 225 fuel body I had picked. As it pulls way more current than the standard pump, got a new feed from the battery running off a relay on the existing wiring.
The new pump is much, much quieter than my old one which makes me realise how shagged the old one must've been. No problems since but now I don't run less than half a tank on track for safety.
On another note, the fuel body that came out the tank of my R26 was completely different to the 225 one bought. The fpr is much smaller and the whole body looks cheaper. Will take some pics and post here next time I have some time free in he garage.
Got some pictures of the R26 fuel body with its different sized fpr. Renault must've changed the unit from the phase 1 Meg, and I am sure that someone told me this before. From memory it was Christine Bock's husband who had the forged phase 1 inferno 225. He also had problems getting a decent fuel system. Must get in touch with him and ask him what he did in the end.
Anyways, here are some pictures of the R26 sender and fpr
Don't know if anyone recognises the size of the fpr, but it's definitely smaller than the phase 1 Meg one and the rs250 one.
Does the dw65c have its own pressure regulator? Also walbro makes a drop in pump and a guy on Facebook has it installed @Ewan and thank u for the pictures
Sent from my SM-G920F using Tapatalk
No, the dw65c is a drop in pump but runs much quieter than the Walbro. Would recommend the dw65c over the walbro, although it's a few quid more expensive.
