Megane RS Megane 250 Lux - unexpected purchase!
Maybe light use is the issue. Mines solid at 60k driven like a toss bag everywhere!
Though your 100% right, would be daft not to have an overhaul/refresh while its off
I done a bit of research on it and read about the diff bearings failing at mileages as low as 5k miles, Bad batch of bearings apparently. A lot have had gearbox rebuilds or swaps in warranty period. Shite gearbox really compared to mk2 ndo which is quite strong.
A friend of mine had his diff rebuilt on a low mileage 275 trophy, I say rebuilt, I mean had a new diff. Crazyness
Good info cheers guys.
Apart from the PK4018 code on the box can I tell that its a diff'd box by looking at it? I know the NDO had visual differences on the shaft outputs didnt it? Any tips like that for the PK?
Cheaper Labour to pull box, examine and fit new rather than rebuild and still not know that everything else has been checked and double checked.
Also Means Renault know the box has come from the factory correct and there “shouldn’t” be any issues and if there is, they can take it up with that supplier/ factory.
Where did you get this done and how much did it cost?
£250 inc the vapour blast. He was very complimentary about the quality of the diff in it. It's a place next door to my mates Ian's MOT centre, on the Lakeside trading estate in Redditch. He did my R9 box too. First time I have used him, but came on Ian's recommendation.
While you've got it sat there, mind taking some measurements for me?
First off I'm interested in the width - bellhousing face to end face that's in the wheel arch.
