Still absolutely loving this little tarmac terror. I hadnt done the brake fluid or gearbox oil since I bought it so... I did those.
Sucked the old fluid out of the reservoir with a home made syringe thing, needs to be thin to get right to the back
RBF 660 and an Eezibleed, no issues really, it all went swimmingly
Old stuff wasnt too bad at all.
Thinking about a Brembo conversion now though. Be rude not to.
Anyway. I digress, dropped the undertray and drained the 'box oil. Fairly simple. Used my pump to pump in the prescribed amount (these aren't fill-till-it-comes-out apparently, though after I filled it I could see the oil level through the hole so its about that level anyway. And if you dont have a pump for filling gearboxes you SO need one. Makes it miles easier. Was about £20 off ebay.
Noticed while I was under the wheel arch theres a bit of a dirt trap around the back of the arch liner.
Even under the sound deadening
Cleaned it all out, must have been half a kilo of crap in there! And damp. Glad Renault have sorted the chassis protection out, 20 years ago and that would have been a hole in the floor by now!
