I know what you mean Riccay, I’m the same with my dealer, but I’m sure if my parts guy departs, I’d be back to square one..
Relationships are long forged.. but easily broken.
Unsure, changes are happening at work in the next 12-18 months which might mean needing a van. Of course I'll go Renault with a Trafic but it might mean having to sacrifice the Clio. Long way off but pre empting a potential change with work.You would have to have good eyesight for sure. Its a long way from your place.
I assume you are selling it then and going old skool?
It's really not good, I know we can be seen as small fry but if they knew half the dedication we have to the silver diamond.....I know what you mean Riccay, I’m the same with my dealer, but I’m sure if my parts guy departs, I’d be back to square one..
Really like the look of your car @RicardoWheel bearing fitted, fresh Motul 600 brake fluid and genuine bleed nipples from Renault fitted on the rear calipers. On picking it up at Eds workshop we discussed a couple more jobs I'd like doing, Type D coolant change and the aux belt kit. I popped into Renault on the way home and picked up enough coolant to add to what I already have and will order the aux belt kit from RPD.
I think once those jobs are done I've then covered all the service items for the age and mileage (91k) of the Clio
Another job I'd like doing is a wheel refurb on the Trophy wheels as I've kerbed the edges slightly on the front 2. Which means swapping to the 17" black Cup wheels.
View attachment 219492View attachment 219493View attachment 219494
Thank you, I noticed on the black vinyl roof there's an ever so slight bubble on it. I'm either going to remove it and just leave it all white or go for a colour change like a Matt grey. I don't mind the black itself it's the nature of the vinyl not being up to spec like paint.Really like the look of your car @Ricardo
I reckon a deal could be had.Thank you, I noticed on the black vinyl roof there's an ever so slight bubble on it. I'm either going to remove it and just leave it all white or go for a colour change like a Matt grey. I don't mind the black itself it's the nature of the vinyl not being up to spec like paint.
I'd still like to get it up to RS Tuning to make sure it's running ok but those prices for power runs mentioned the other day were a bit
If that's possible that would be brilliant, I can sort a day off work thenI reckon a deal could be had.
