Renforced clutch set 370 euros - Adjustable cam gear pulley - Racing gasket
B
Benver
Hi the board
We are glad to inform you about our new items that we have just received in stock
our latest developpement which is an competition clutch set including
- 5 Paddle clutch disc
- Renforced clutch pressure plate
- Renforced bearing
This clutch set have been tested for a long in high uprated engine you can see the dyno screenshot on our website
We got only limited quantity in stock of this set
http://www.mespiecesauto.com/moteur/149-embrayage-renforce-r21-turbo-.html
Adustable cam gear pulley
Price including shipping is 90 euros available in blue or red
http://www.mespiecesauto.com/moteur/152-poulie-arbre-a-came-reglable-r21-turbo-j7r752.html
Multi layer cylinder head gasket with separate rings
We have developped special real multi layer cylinder head gasket with separate rings.
Usually competition gasket is made from original gasket where we apply stainless steel layer, but the basis is standart gasket.
Here this gasket have totally develop has competition gasket, and the separate rings is the best solution for high pressure, you can run more than 2 bar.
http://www.mespiecesauto.com/joint-...de-culasse-renforce-r21-turbo-competiton.html
For any information feel free to contact us or by phone +33 669670951 or by mail [email protected]
240 euro's for a headgasket :eek:
Yes but nattman you should know because you know quite well spare part price that all separate rings even to Cometic range, it's called Cometic Phusion is the same price
If you prefer to have normal gasket we have it for nice price for example Victor reinz set of gasket 100 euros delivered, but you have to compare what you can compare.
These gasket is for real uprated engine, many french owner used it for high pressure and be sure that even French people is not so stupid to pay 240 euros for a gasket if they can have the same quality at 50 euros :biggrin1:
with my best regards
Ben, you selling quality stuff on you're website and even recomanded you're clutches on here.
The uprated headgasketstory is rubbish, sorry mate. The std headgasket handlles more then 2.5 bar boost. Its all about the map (eprom like you prefer). When there is a problem with the map, first thing that goes is the hg. If you replace that with steallayer or something similar then the problem move's further down. Liners, seals a.o.
Victor reinz wouldnt use those gaskets if there anything like the 5 gt ones they are cheap and rubbish , in my opinion
Hi,
Has anyone installed this uprated clutch unit?
Set of renforced 5 paddle clutch disc, renforced clutch plate and bearing. Test and approved on engine bench at more than 400hp and 53m/kg of torque
Any feedback, good, bad, indifferent, please let me know.
Thanks, John
I've got one but not fitted as of yet! Think danb got one the same time as me but don't know if he's fitted his.
Lol just looked on the site.....was unaware they did alloy radiators. Am hovvering over the 'buy' button then I clicked to view in full size and erm........is it me or does it look 'pissed' lol
Maybe it was made to fit a certain car with Cadburys racking upfront or that Black Quadra with half the subframe and chassis rails removed pmsl
Afraid i'm not aware of anyone that has. Jo would be the best person to ask I expect they have been used on the continent.
---------- Post added at 10:04 AM ---------- Previous post was at 10:01 AM ----------
I wont swear cos even though you criticise, it's a proper weapon and i'm gonna splatter you all over Devils Bridge on the way to Joff's. You twat.
