Hi all, I hope you can all help me with a worrying problem. Before I start, I wanna not that I have a Renault 21 1.7 GTS 1992 model, F2N motor with A/C installed, but currently not working, hopefully it will be filled next week.
That is I started noticing when it started to get warmer outside that the electric fan(s) won´t start. We pulled out the switch and measured it with a DMM and measured 0V on all pins
. So we decided to try feeding the pins directly with 12V from the battery. And it worked just fine, so the problem is not the fans (on one pin, one fan started, on another pin both of em started). So, next step was to check the fuse box. We found the corresponding fuse and measured 12V there, and also constant 12V with the ignition set to off.
So, my question is, should we start taking the dashboard to pieces to trace the voltage? Or is there a common failure known?
Thanks in advance.
If you want more detailed pictures or something like that I can get em with my Canon, I was just lazy and used my mobile.
Thanks in advance.
