Sebsy11
Good evening all. I've been sorting out minor things on our R21 TXE auto when time and health permits.
Blower
Our blower has given up. Blew the fuse with a pop. After months of steamy windows, I've removed it.
When 12v is applied, there's quite a bit of resistance and virtually no movement.
I assume these aren't worth fixing? I've been trying to sort a replacement - does anyone know of any good places?
£240 is a bit steep otherwise! (Part number 7701032300).
Of course, the Haynes manual removal procedure didn't highlight that there is no way of getting to one of the screws in my version without having to remove the centre console.
Heater cable clips
Also, I remember seeing that the heater control clips on phase 1 R21s give up. I can't currently change the distribution.
I'm going to give cable ties a go (bad blurry picture further below). Unless you can get the clips?
General work
Otherwise, progress has been good. Car's been MOT'd for about 8 months. Did a few jobs before hand;
- Cambelt, water pump and service (Mechanic)
- Usual rust at end of one of the sills: welded, repaired and repainted (Painters)
- Gearbox fluid flushed and replaced (3rd which is top gear is still clunky to change into)
- Replaced radiator, cooling fans and some of the wiring (me)
Next plan is to replace all the door lock solenoids. I've had them for nearly a year and not got round to ripping the door cards off!
Thanks all!
Blower
Heater cable clips
General work
Thanks all!
