Rossington
Hey guys,
Last week my fuel gauge decided that was it and packed in. Since then Rick @ Dryclough has fixed everything up nicely, turned out it wasn't the whole fuel unit, just a wire and connector. New wire, solder etc and all is back to normal.
My only issue is the little thing on the trip computer that says "you have X miles remaining before you need fuel" just flashes asif its saying im empty. Obviously i'm not as i filled the tank on the way home and the needle says so too.
I tried the little stalk reset thing with the ignition where all the dials dance around for you and its sadly not fixed it. Do you think disconnecting the battery will help sort it? If so i'm guessing its under the front beneath the cover.
Other than that i'm out of ideas.
Ross
Ross
