r5turbo1988
hi guys.. ihavejust converted my r5 1.4 tse to a 1.4turbo. an engine transplant.. but the problem is it doesnt want to run.. and when it does run u gta keep the engine above 2000rpm. i have changed the fuel pressure regulator,fuel pump relay.. as im sure it is overfueling.. because when u remove the relay for thepump the engine runs til it runs out of fuel.
i think part of the problem is the pipe work for the vaccum if i am right.. if people could send me some indepth photos of their vaccumlaayout that would be really helpful thwe ones which goes to the ecu and all differnet parts around the carb to the actuator fuel pressure reg etc.. idonthave a antiperc fan.... also i have noticed that onto the carb u have the top and all 3 pipes blow air.. are they spose to do this.. or arethey spose to suck.. because i thought a carb is spose to suck.. this is at idle
beforei had this problem i didnt have the restrictors in the crankcase breather system and the car ran but real craply.. every since i put them back in itdoesnt run.. this made me think that it was using theextra air and it was like the fuel isnt being regulated.. if any1 could help me i would be really greatful if u have any questions boutwhat ive got just let me know cheers
