Wanted R5 GTX Sunroof Seal
I looked, but after clicking R5 It asked for different codes. I presume vehicle code or something and I've not had time to look further into it, so I thought it was worth posting a thread and seeing what came up.
Oval plate. Got the reg document? It start vf1 then the next 4 characters are the oval plate number. My 21 is vf1l485 so the oval plate is l485.
There is shit loads of different sunroofs for the super5 the parts listed on the diaologys will be of little use. All were fitted as an option by the dealers from memory, i have seen manual tilt, tilt and slide, electric and even webasto. Have a look at the handle and find out what make you have and go from there. Ebay is probably your friend here match up your current seal and go from there.
Also might be worth checking its not leaking from the frame to roof seal...easily sorted if that isnthe issue
Nice one mate I'll do that, off memory I know their is a make on the handle in white and it's just a tilt sunroof. I'll have a butchers when I get back, search up the make on ebay and see what I find. I take it theirs two seals? One for frame and one for glass. I've been away with work all week so I've not been able to do anything.
