r5gordini
Hi All,
I have embarked on the above project! To fit power steering to my GTT. I have seen this post:
http://turborenault.co.uk/threads/39/page-6#post-8111
But I have questions for anyone that has done this before...
I have bought a Clio Mk I rack...
Here's the R5 shaft:
I have the Clio rack all ready to bolt up (once I have removed the seized track rod ends - grr)! I need to get some pipes made up. Pirtek should do it?? Or Hydraquip? I like the way it was done above - where a fitting was fitted to the bulkhead panel to pass the pipes through but I'm going to have to do it the other side - driver's side. I will probably punch holes through the bulkhead panel.
More photos later...
Andrew
- Did you have to change the rear engine mount as per the above thread?
- Did you have to change the steering shaft?
- The Clio track rod ends are different. The R5 ones are not compatible (internal vs external threads). OK to fit Clio ones?
Andrew
