5 Mk I incl Gordini R5 Gordini turbo dizzy cap and points setup
the gordini turbo doesn't have points., its got an ignition module.
the dizzy mesh gear needs to be fitted before the head goes on the block too. Usually so the slot is at 12/6 oclock, with the fat side to the right. it can be adjusted though once the head is on, by lifting and rotating.
dizzy holding down pins? no such part i'm afraid. do you mean the mesh gear, the dizzy body, the rotor, the dizzy cap, the dizzy clamp , the 11mm dizzy clamp bolt, or the two screws that hold the dizzy cap onto the body?
