R5 gordini parts needed
herb2000
Hi gordini boys!!
Need a bit of advice!
How to assemble the rear seats (photos preferred)
Parts required below
Both rear seat belts
2no dashboard panels, above and below the steering column
Wire from the ecu (not called that but dinner no what it it) see picture
And a Rev thingy!! See pictures
Will put pictures up tomorrow
Ref rear seat belts, has your car the mounting bracket for the inertia reel welded to each rear turret? If not you can fit these non inertia ones , which do bolt straight in to the bolt holes already on the car, easy install and you know they are good quality. You can also buy just a lap belt if required.
See the link, my old red car had the bracket as per the photo in the link.............
http://turborenault.co.uk/t15144/
I also purchased the front ones which were a bit more tricky to fit as I had to modify the bracket from the old seat belts, but got there eventually.
http://www.ebay.co.uk/itm/Renault-R...635?pt=LH_DefaultDomain_3&hash=item3f20bb2e43
Split rear seats for all Gordini's, single for le car turbo, the pivots points are tight to get in, I use a long bar to lever the pins in..................
Below is the pivot to one side.........
Below are the pivots in the centre of the two back seats, the spring washers fit onto on the white ptfe washer
Below, general arrangement of the 't' bar section, probably best left to last
Below, my new diagonal rear seat belts, when not in use the slack goes behind the seat, simple install just 3 bolts, holes are already in the body shell, just remember to use a short bolt at the top anchor point otherwise you can screw through to the rear hatch and damage the body.............
I am sorry for the delay in getting back to you about parts. I have not visited my unit in some time. Hope to get there soon but I am sure I can help you out
