Hi all
Having a bit of a problem with the clutch on my R26. When releasing the clutch after changing gear, the pedal will stick half way! So I then have to use my foot to flip it back up to normal position.
Weird thing is it doesnt do it all the time, however it does do it a couple of times a day.
Whilst driving to work this morning, I got a load beep, with the engine management light flashing and a 'braking failure' error message.
I then checked the fluid level and it has definitely gone down as I check them regularly!
Anyone have any ideas what the problem is?
Also, does the clutch and brake system use the same reservoir?
Thanks
Thanks
