I am from Lithuania, so i'm sorry for my english in advance.
The question is: is it possible to swap the r19 16v front ant rear brake discs with calipers and stuff on the r5 gtx 90'(front discs, rear drums) ? Thank you.
Front has been covered in the tech article sections. for the 259mm brakes you need at least 14 inch wheels though.
The rears you would be easier getting a GTT rear beam, if thats not possible a clio one. if thats not then you need to take the 19 16V calipers and caliper brackets and spacers and fit them to the 5's axle, also you need gtt handbrake cables and make up new brake lines.
