project pickup
misterjay
this what i could look like as this will be new to as i aint done anything like this before but when i start the project i will be doing a full report on it so wish me luck with this one guys ;);):eek::eek:
parts list
1: 3 door car or rollin shell
2: sheets of steel
3: angle grinder
4: welder
5: box section tube
6: rear window
7: body filler lots of
8: wet and dry paper lots of
9: time
10: people to help as many as i can get
I've got a tip.
Don't cut up anything that's a monocoque shell. There is no class in the new IVA test for a conversion to pickup and so you'll never get it legal until there is. Even if there was you would have to build it and renew everything else to make sure it's up to IVA standard.
keep it to paper.
I've got a tip.
keep it to paper.
BIVA does allow for pickup conversion but it has to be within goods vehicle limits- ie bed dimensions, gross weight, loading weight.
Basically, as has been said, because you will kill a bus-stop full of nuns carrying orphan kittens to a church raffle if you even contemplate removing the roof they have made it hell.
In fact, it has been hell since 1998.
Looks good though :)
--Phil
Just checked. SVA still appliccable for converted goods vehicles until October, but that'll only be granted if they believe the vehicle's primary purpose it to haul goods.
BIVA has no test (I read wrong) for vehicles converted to pick-up.
In short, you can do it but you can't register nor drive it on public roads.
--Phil
as for the legality, there are several pick up conversions on the retro rides forums which are being used as peoples daily cars, how did they go about making them leagle, may be worth asking on there
