Power steering pump
roma
Have a leak on the power steering pump, Does any one know if this can be changed with out taking the engine out. And are they difficult to source.!!
Thanks Tony
Not difficult to source. I have a few new ones but where is it leaking from? I had one leak on the union once. Was nothing more than a rubber O ring.
Will have to look more closely, Hopefully just the o ring know you have mentioned it. Thanks Brett
If it is an O ring, make sure you get a genuine Renault one. I had a million and one and thought I put the right one in. Weep after weep it was a 3 quid part from the dealer that stopped it.
There is a bleed on the top of the circuit, mine came undone and looked like a major leak, once all covers off it was obvious and took a couple of seconds to tighten up.
