I should imagine that you have either snapped one of the breather/vacuum pipes around the throttle body which are VERY brittle or have a loose connection/disslodged pipe somewhere. I snapped my hoses and instead of replacing them with an OEM parts that will do the same, I converted them to rubber.
Thanks It has also, just occurred to me that when i found a failed coil, I assumed it was the only failed coil. I checked 5 out of 6 [smilie=doubt.gif] Silly me.
Thanks for this. Eventually found the breather pipe you described had come out of the section of rubber pipe it joins to. This came out when I had lifted the plenum the first time.
