The 99 megane scenic ones fit, work and look extremley similar, but the ones i got a few years ago were not 100% identical. The electrical connector on the back is ever so slightly different from memory (but just fits).
If you changed both at the same time only the keenest of eyes looking extremley hard would ever know.
We discovered the Megane lamps fitted a few years back when Duncan and I both needed them. I had a Meg Scenic work car at the time, and by chance noticed the appeared to be the same. Looked into it with a friend, and they were! Duncan tried them in his Ph1, and although they will fit, they are very slightly different as he mentioned above. The lenses are now clear, without any ribs in the glass as original oem to the ph1. IIRC
