BigfellaV6
I took my V6 ph1 down to my local garage last week. To check out my front fog lights which haven't been working since purchase a couple of years ago.
After inspection I've been advised the wiring loom that connects to the rear of the fog lights has worn & will need part replacing. Unsure if anybody has experienced a similiar issue? However if somebody can please point me in the right direction as to where I can obtain replacement wiring & connectors then that would be much appreciated?
Unsure whether its the same the same wiring & connectors that you find on a similiar year 172/182. Presume there the same foglights?
Thanks
Thanks
