ph2 wheels on a ph1
johnler":349fm42v said:
Hi guy's I've got ph2 wheels to go on my ph1, can any one tell if they are a straight swap, ( no spacers)
You'll need to fit 20mm spacers and longer bolts on the rear fella.
your a star m8, You said it before but I thought you just meant to fill and make it look better, I noticed today there's no clearance between the struts and the tyre's,
10mm necessity, 20mm fills the arches. Some have said spacers affect the handling slightly so I went for 15mm as a compromise.
Gut which are the best size 10/15/20 wheres the best place and how much or has anyone got a spare set to sell, cheers guys
also what other cars will these spacers fit, so I can look on ebay ( ie will Bmw ones fit etc)
