Charliechod
petrol light comes on of the gauge any body no how many miles r left in the tank x
Cold fusion":1hwh3d99 said:European directive states that the fuel level in the tank when the warning light comes on must be sufficient to travel 50 km.
Nigel.
James":l6r41uju said:The handbook just says:
Low fuel level warning light
If it lights up or remains lit, fill up with fuel as soon as possible.
A few owners suggest there is approx 30 miles left when the light comes on.
WONGY":1xzf2pb1 said:I was told its best to keep the tank above 2-3 gallons otherwise your fuel pump will rot away
Thats what happened to mine when i first got it, cos the dealer had the car on the forecourt for months with low fuel so it wasnt fully immersed. When they took the fuel pump out and shook it, it sounded like sand was in it which was actually rusted metal!
Had also heard that running fuel damaged the fuel pump in some way but dont quote me on this just the first point
if you send me your sender unit, i will swap the pump for £120 , test it for pressure and volume and post it back to you all in provided there are no problems, problems come at an extra price! i do have a spare sender for both ph2 and ph1 which i will swap with you for a little extra to save you waiting, would need a depo on this as they are 400 quid. also have the correct tool for getting the top off without smashing it to bits, this i will loan in with the deal.matt81irl":1xb2bthf said:I've run out of petrol twice within 5-10 miles of the red light coming on! Sooo embarrassing, lol.
Few interesting posts about leaving the sitting for a while. Had mine parked up for well over a year there and recently completed its major service + extras. But never thought about the fuel pump. Just recently while driving when my petrol is low, the car does judder a little or hesitates! And last week a heard a very feint whine, which when I give it a little throttle stops!
So spike how much are these pumps? Lol
Allstarsam":2yfccmc6 said:An ex vee owner told me that his car once failed to start due to an empty tank before the yellow fuel light had even illuminated! The above post is definitely sound advice.
