Hi all.
Just wondering if anyone else has had the following.....
Driving along and the central "electronic problem" (rectangle with the zigg zag line inside) warning light comes on in the display, engine stays running at idle but has no throttle response at all. Then i switch off the engine & re started it & all is ok again for the rest of the 30 mile journey.
Then sometimes when i start it the same warning light comes on straight away & it will only idle again, switch off ignition & re start it & it's all ok again.
I'm getting the following code & message when i plug my basic diagnostic tester in... P0300 code & "Random/Multiple Cylinder Misfire Detected"
I presume this is probably one or more coil packs starting to give up but without knowing exactly which one i may have to change all 6 which is a pain & expensive.
It could of course might be something else causing the "random multiple cylinder misfire" so does anyone have experience of this fault code & symptoms ?
Looking forward to any info
Kindest regards
Jules.
Kindest regards
Jules.
