My oil & stop light flickers when the engine is warmed up after driving for about 30 mins just had oil & filer changed it wasn't doing it before I had it done.. ?
Is there an oil temp sensor near the oil filter that might have been unplugged?
Is the loads of oil leaking underneath your car?
Sump plug and washer not fitted properly?
Oil filter loose?
Have you checked there's enough oil been put in?
IF it was just the oil light flickering when the engine is hot and on tickover that could be low oil pressure, caused by worn engine internals ! But yours sounds more like a wiring fault with the stop light flashing too , :approve: Did you use the correct oil and filter ? (Oil pressure switch faulty ? )
when I got the car back lots of oil was leaking form the filter he the checked it & said the filter was loose ? don't know why it was loose if he had just fitted a new one ? he did say if was very hard to get the old oil filter off so now Im wondering if he damage the oil cooler taking off the old oil filter ??
