As far as I recall the car was standard. It had been Superchipped but was reverted to standard map as advanced ignition and nitrous don't mix well.
I may have had a filter on. Setup starts from about £5-600 if you install it yourself. Mine was quite a bit more as I had 2 big polished bottles and a Progressive controller.
Insurance; I'm with Greenlight, massive list of mods including nitrous, all declared, £900.
Roundabouts can be interesting in a standard V. Nitrous is for straightline blasts.
50 jets will be fine but the 255 seams to have a weaker clutch for some reason.
simon ...if you fit it just get going before you use it...3rd and 4th gear it is awsome..
Yeah I've had one new clutch already (at 7500 miles, warranty job)
but yeah I would use more for in gear accelartion mostly I guess, I don't do "Stanta Pod" days....lol
Although I see Yozzsport has an uprated trophy clutch, do you know anything about them?
I run NGK along with Trophy coils. I can find part numbers if you need. Really worth doing the coils too as they give a much improved spark which you'll need to get the best from the nitrous.
Note that Nitrous was activated at about 2700rpm.
If you activated at 4500rpm obviously you'd get a totally different chart and the massive torque would then come in there rather than tailing away by then.
