Need help please
blownaway87
Hello everyone, I have a 1997 renault megane RT with the 1.6liter with a manual transmission. I recently changed the heater core, which was completed plugged up and at the same time correct the click click issue from the blend door motor. After all was said and done, now i have a strange issue, when i leave the head lights on and hold the brake with the key out of the ignition cylinder the dash stays illuminated like the key were in the "On" position, but when i turn the head lights off it won't do it at all. I already check all connections for a possible broken connecter where wires might be touching each other and i check all relays... Any ideas.
also after Heater Core replacement, the head light and high Beam indicator on the gauge panel no longer illuminate even after i changed the blubs.
Also the cooling fans will not turn on, i have check the fuse on the fuse block under the dash and there is no power on either side of the fuse or at the pins.. the Radiator fan has a good ground .
