Just taxed the car today after its winter break,took it for a 10 minute drive after about 20 minutes car would turn over but reluctant to fire,remember this happened alot last year fine when cold started first turn of the key.
Check the fuses in the boot. I used to have the same issue but not anymore thanks to Brett. Do you put anything in the rear? I used to store bottled water which obviously knocked a fuse loose.
