taipan":1tw1iqbf said:Oldskoolbaby":1tw1iqbf said:I think I may explore the MK2 gearbox option (no idea where to start!!) and also maybe have a look at some KWs. They are pretty expensive mind... :s . I've already got some MK2 wheels to go on (really that much heavier??) so bigger brakes will definitely be a future mod.
The gearbox will not be hard to fit fella. Finding one might be the issue though. I did have a loads of info somewhere regarding the different ratio's the PK6 box can offer. Wheel wise, I think the ph2 change is a brilliant one. Ive said before, I drove Bill Patchall's car on a damp/slippery Bruntingthorpe and it was superb. To the point where you realise that the hype of the V6's tricky handling has been blown well out of proportion. Combine the wheel change with a set of coilovers and it would definatly, 100% transform your vee to another level.
I remember speaking to a engine tuner about our engines and they said the inlets plenumns etc aren't the issue to making more power. Its actually the area around the throat of the valve. I'd be interested to see what the gains would be if the heads and cams were improved upon on a stock ph1 motor using the standard plastic inlet.
