Mk 2 inlet plenium
steveukv6
Hi all, does anyone know if a mk2 inlet plenium will fit straight onto a mk1? Is this a good place to start tuning? And how much do they sell for? steve
It does fit straight on but comes with a bigger throttle body which ideally needs some remapping to make it easier to drive. Mine has a non-linear throttle map at the bottom end otherwise the throttle becomes a bit like an on/off switch when pulling away etc.
Scott at SG Motorsport http://www.renaultcliov6.com has plenum/TBs and may know someone who can remap, otherwise I can recommend someone.
Scott also has grey injectors which are worth doing at the same time.
Tim
