METHONUL
boyne
Does any one know, or has used Methonul fuel mixed with regular petrol in the Vee ? can it be done or or will there be any damage received to the vees engine. Methonul fuel is used a lot for speedway i know but can it be addapted for greater performance in the Vee or cars in general ?
Roy.
In general,
Methanol eats away every standard rubber seal, so probably it will start to leak at every joint, not to forget the fuel lines close to the tank.
You will need to replace them with Viton, or plastic which resists Methanol.
Hi,
Methanol is not just poured in to petrol and stirred, it is added attomised under pressure to homoganise it with the petrol which is heated to increase its viscosity. Its mainly available in north and south America to increase the performance they only blend their petrol to gasoline standard (about 88ron maximum). The fuel pipes are nitrile lined.
Cold Fusion.
