Megane Meglio vacuum lines
Paul330d
Hi Im in the process of building my Megane rs 250 meglio which I have used a Megane rs 225 intake and throttle body and was wondering if anyone else has done this ,as I'm struggling with the vacuum lines ie brake servo line and turbo vacuum lines photos and parts used would be a great help .
Many thanks Paul
250 engine on 225 management is easy.
The 225 inlet manifold port match is terrible on 250 head, use 250 inlet manifold with adaptor for 225 throttle.
Block the hole on throttle body, Use 250 servo pipe. I blocked off the breather on inlet and bunged the port on breather plate and bunged the spare port on inlet.20230707_112553.webp20230318_153346.webp20230318_153343.webp
Block the hole on throttle body, Use 250 servo pipe. I blocked off the breather on inlet and bunged the port on breather plate and bunged the spare port on inlet.View attachment 220062View attachment 220063View attachment 220064
Thanks for that I was told that you have to use the 225 inlet and throttle body , where did you get the adaptor plate from ?
Veban motorsport do a nice billet adaptor to fit 225 throttle on 250 inlet.
