Si.
Ok so my window stopped working. It got stuck half way open.
Took the door card off and checked the regulator. The wire had snapped and wrapped itself around the motor burning it out
I have purchased and fitted a replacement motor and module along with the metal runnerst and cabling
Now the weird bit. The window still wouldn't move. I discovered if i move the motor towards the door the window would go down. Move it away it would go up
Thinking this I replaced the door loom also..still the same problem
Once I bolted it all back together just so I could use the car the passenger window also stopped working! If I unbolt it all the passenger one works and still have the same issue with the drivers?
At a total loss with this now and it's making me wana get rid!
Anyone got any ideas? The motor and module was a tested 2nd hand unit and the runners and cables brand new
Google doesn't seem to help on this one!
