Hello,
i am a little bit desperate so i will try my luck here. I am owning Megane III GT220 but i am very unpleased with the position of gas pedal. It is way too on the right and drowned(?) compared to break so even if i break hard heel n toe (or maybe better to say "toe n toe") is big problem for me.
Here are my questions, hopefully someone had same problem (even in other recent renault car).
1) From what ive been told its impossible to move gas or brake pedal in some simple way. Is that correct?
2) If previous is right, do you have any - preferably simple - solution in mind? I browsed internet from start to end and only thing i found were some fairly bad looking pedal pads which could be mounted on top of current (original) pedal, which doesnt look very appealing to me.
Thanks
Thanks
