Megane Coupe 2.0 16V Ph1- 1997
Peter T
Well I better start a Report for this car even tho' I've ownded it for 3 and a bit year's. After it's M.O.T test earlyer this year. I got 3 advisorys. on front brake disc wear. coolant leak and worn Ball joint's. However I knew it was more than just worn joint. with having the rear end shaking about a fair few time when hard on the brake's. In a stright line. Anyhow with a bag of spanner in han. I set about sorting one side of the suspension with new wishbone's from BypartsBuy. I'l be on the the other side When I feel like doing it. As the car not in use as it's on a S.O.R.N. Any how no pic's of the job in hand just one of the old Wishbone.
Once fitted a shakedown check was made on the small amount of road outside my home. just to make sure everything it tight. and settled in right. I will be doing the other side,and the same very short test when that done. Then a look around all the nut's and Bolt's when the Water pump come's out to sort the Leak.
18th July 08
I've done the other side's Wishbone Same as above Really.
