Megane Megane 225 cutting out under acceleration
Josh lowe
Hi my first post on here , I have a 2008 Megane 225 cup , I did a track day in it at the weekend and absolutely loved it , but in the last session it started cutting out under hard acceleration for about 2 seconds then the power would come back , if i put the pedal down to the floor gently it will pull all the way to the red line , but as soon as I try to accelerate hard it cuts all power off , has anyone ever come across this ? Thanks in advance, josh
Could be a few things this @Josh lowe
1) N75 valve that bleeds off the boost is failing
2) Injectors are on the way out
I would be looking at option 1 first. Sounds like overboost protection or something of that ilk.
I had a very similar problem on my megane 225.
Diagnostics were pointing to a bad N75 Valve but it wasn't that , see :-
Megane - Running Problems - Fuel Pump ?
The problem was only at top of rev range to begin with and over time (as the pump became more worn) it spread lower & lower to the point where at 3000rpm at full throttle it would cut power off.
I would suspect a failing pump if the problem starts getting lower into the rev range. If you have a OBD2 scanner, check the fuel trims as it will help diagnose if it is this.
