Eder
Hi guys,
I would like to know if someone has had this clutch problem.
I have a Fluence GT that uses PK4-017 gearbox, very similar to the PK4-018 of Megane RS mk3.
This Saturday, the clutch pedal simply stayed low after I pressed it while driving the car out of the garage.
I had to pull the pedal back up and insist some times until it regained pressure and worked again.
Apparently is appears to be the pedal master cylinder, because I did'nt see any leaks...
