Long clutch pedal
HaventgotaClio
Common thing on a V6 or sign of an issue? Can it be adjusted on the clutch cylinder or pedal?
Off to SG Motorsport soon so hopefully can get it sorted.
When I drove mine the other day - I thought, ‘flipping clutch is heavy!’
Once, I was used to it, got back in the BMW and thought, ‘flipping clutch is light!’ :)
Ask SG or Jamie to test drive it. They’ll give you correct advice.
Probably needs bleeding and the fluid changed as first port of call, as it is hydraulic it should be self adjusting so excessive travel is probably air trapped in the system.
