5 Mk I incl Gordini LECar Turbo Crank trigger pattern
Kevin Leaper
Hi
I believe my 1985 LeCar Turbo has a crank sensor, but I can't find any info on the trigger pattern -ie the number of teeth and the position of the missing tooth relative to crank TDC. Can anyone help?
Cheers
Kev Leaper
They were too small for my use, the way mine made torque meant they were effectively flat out at 300lbft.
Scoff swears by them because they're normally so manageable across many formats. Sure he recommends them to EFi 5GTT boys and 1*2 lads alike.
Sent from my LG-H850 using Tapatalk
They sound like what I need,but wouldn't mind chatting with someone to see if they are suitable and not too big, but am away to France on hols for 3 weeks, if you still have them when I come back I will get in touch. Thanks
Yes I have. I'll dig them out. I'll send you a PM.
Andrew
Hi I now own kevin leapers old le car turbo might you know what flywheel is fitted to this regards diameter as I'm trying to source a uprated clutch for it I presume its 180mm any info would be great , might save me pulling it out to look at the moment
Thanks Nathan
Thanks Nathan
Do you know what crank position sensor it is running? also if you look at my thread there is an option for uprated clutch on there
5 Alpine Turbo thread
Thanks
Gary
