Tony Smith
So I picked up the 205GT Laguna today that I was planning to use for a Clio transplant. Its much to good to break so providing an can sort the following 2 problems at reasonable cost I'm going to sell the Safrane and use it has my daily for a while.
Can anyone help with the following
1. Car runs perfectly round town, under boost, hot or cold. On a motorway run I'm told it will regularly conk out and then not start . After a while it starts and runs fine again. Seeing as its basically the same engine as the Meg 225 I wondered if anyone had had the same problem, or a clue what's going on.
2. Has a new key card with it and although it starts with it in the dash and the car locks itself once you get out of the car , it will not work the central locking, so you have to open the passenger side with the key and if you don't get the key card in the slot quickly the alarm goes off. I thought this might just be the card reader in the dash not sensing the card?
Any help or advice is greatly appreciated
