Hi,I have a 96 mk1 1.8, 8v, 1783cc single point injection laguna hatchback.
when starting from cold in warm/hot weather it needs throttle and tries to idle at 5-800 rpm also it does not idle evenly ,even if you hold it at 1200 rpm(but idles ok when up to a working temp),when its colder outside the cars starts fine with no throttle and idles about 1200 rpm slowing as it warms up.
I`ve noticed when its cold the stepped/idle motor moves to adjust the idle,but it does not when it warm/hot outside.
I have changed the coolant temp sensor and it made no difference.
Any body got any ideas ??.
Thanks.
Thanks.
