G
Guest
Had driveshaft/cv joint failure, and also found my circlip had popped, fitted new circlip and fitted new driveshaft but with it in gear it doesnt hold the shafts from turning...so im finding it really hard to tighten the hub nut up.
I presume this is down to the circlip, but as i havent started the engine, moved it or anything of the sort, just popped the shaft in, it shouldnt have popped surely? Unless my gearbox is stuffed.
Any advice would be much appreciated, need to check if the circlips still in or not really, but got work soon so shouldnt really get all dirty.
