Interior restoration / mould / options / advice needed
Duncan Grier
So as per my thread I am starting the job of removing and cataloging the items along with quick clean / review to revisit after the shell is sorted
So hot topic is mould on seats and advice welcomed
In terms of the seats I was going to air, good hoover and poss white vinegar mixed with water to hopefully sort the mould and dry review status
Will need to change one of the bolsters which seem available
Any advice on 5 interior? Can you get the material / pattern as an option
Seats seem the worst but will know more when out of the car
Feed me info and options
DG
I had mine do the same when under a cover for a while and I had to drive it as I was moving that day when I found it. Dettol wipes came out, good scrub and mould was gone. Expected it to come straight back within a month but it never did. Quick and easy.
Thanks all, will try a good hoover / clean and if it returns can get serious with it
Cheers all
Not even looked at the carpet and nothing is worse than the windscreen surround lol
Anyone know of a 5 breaking / scrap that has solid surround I can cut out ;)
R19 front leather seats.
hey guys are the front leater seats interchangeable?
I can get hold of a good passenger seat, can i put it into the drivers side withut any mods?
cheers.
The seats are interchangeable but the bases need to be looked at and depending on model, your seat buckle might be the wrong side of the seat, in addition to the reclining knob.
Just read this one.
Hoover it off, then steam clean.
The steam will kill off the bacteria that's grown behind and inside the fabric so you'll get no bad smells coming back out.
You can always wet vac them too but I tend to use it as a last resort on older seats as the foam and bits degrades over time.
