Modern Injector changing meg 225/r26
andybond submitted a new resource:
Injector changing meg 225/r26 - Injector changing meg 225/r26
PDF version available to download , see above. Thanks to Joe r26 for this
Just removed my injectors for cleaning, so I thought I'd make a quick guide for others. Its a fairly straight forward job that most should be able to carry out with basic tools and should take no longer than 30 minutes.
Tools I used...
7mm, 8mm,10mm sockets
8mm ratchet spanner
Flat head screw driver
Firstly I removed the engine cover. You may want to disconnect your battery that's entirely upto you....
Read more about this resource...
